How about Average Bitrate for all Encoding Codecs?
    After learning about Average bitrate, I found that it was fantastic in the sense that it was a balance between a VBR and a CBR. Now, this would be great, since most songs have a complex and a simple part. People would also have limited space sometimes, and so they are stuck on a CBR most of the time if they are limited.
    So, the ABR would then work like a VBR in compressing the simple parts further, and then keep the complex ones with a higher bitrate. Now, this is the difference. The ABR would then generate a filesize which is nearly identical to a CBR file, which means that people get higher quality audio with a predictable filesize.
    As far as I know, only the MP3 encoder has the ABR function, none other have them. Wouldn't it be fantastic if we could have ABR on all of the codecs that do the encoding?
    Re: How about Average Bitrate for all Encoding Codecs?
    It would have to be written into the codec its self (Ogg has abr), rather than dMC to add it somehow.
