Do you have a codec for .ADF?
  • In dispair
    Do you have a DMC codec for the audio format ADF?
    Re: Do you have a codec for .ADF?
    .adf stands for Amiga Disc Format. It is not specifically a format for encoding audio files. dB does not have a codec for converting adf. If you can play the adf file you can try recording the music from your sound card as it plays using Auxilary input.
    Bill Mikkelsen
