add preset medium to lame
  • fecund
    • Sep 2002
    • 22
    The list of presets for lame is missing "alt-preset medium" (it may be new, I'm seeing it in v. 3.96)
    Re: add preset medium to lame
    Try the Lame CLI Command line encoder (in Codec Central), I dont think that preset is exposed in the lame.dll.
    • mantra
      sorry spoon a question
      i downloaded the last lame version
      and i copied in the dBpowerAMP dir
      but when i select Extreme preset dBpowerAMP encode but not in etreme preset!
      i compared with the lame.exe
      mantra
        You mean the files created are different?, to compare files you need the same version of lame.exe and the dll
