batch conversion
  • Ronin
    • Mar 2004
    batch conversion
    The program should be smarter when making a btach conversion, interms of bit rate. I recently converted some 780 files, whose BR varied from 64 to 160... I initially used 112, but some of the files resulted way bigger than the original (obviously). Then I used VRB 64-128, but the problem persisted. Considering that there is no imediate reason for converting a file from a lower BR to a higher one, I think there should be an option to "snart convert", leaving to the program the coice of converting or not based on the original files settings and the conversion choices.
    Of course one can do it for oneself, but then its a file by file work, which is quite not the idea...
    Re: batch conversion
    There is hope that this feature may be in the works. The beta of dCW (dB CD Writer) has a smart conversion option.
    Bill Mikkelsen
      • 46167
      You could load the tracks into dBpowerAMP Audio Player and sort by bitrate >> right click >> convert to
