Ease of use issues
    Ease of use issues
    While the modularization of the program makes it less of a burden on my RAM, it would be nice if the individual modules would acknowledge each other. For example Im in MMC and i decide i want to send some files to my mp3 player, it would be nice to be able to say right click on the files and select "send to mp3 player." Or if i want to make a cd there is not option in DAP to go to the cd creator program i have to go hunt down the program myself and run it seperatly. So it would be really cool if this type of thing were available, mostly from DAP since that is what i run constantly...
    anyway, hope i didn't ramble too much,
    MATT
  • Wayne
    • Aug 2002
    • 1254
    Re: Ease of use issues
    These features should already be available or are currently available in the latest beta versions.
    As long as you have the correct codecs present when you select to convert a file, doesn't matter where, you can select a variety of formats or alternatively recipients. It is therefore possible to 'convert' a file and:
    1. send it to 'Audio CD' which will send the file to the CD Writer program.
    2. send it to a MP3 device.
    Both these options should be available from MMC, if you have the other dBpowerAMP programs installed.
    I think that the latest beta version of dAP allows the music collection to be sync'ed with hard drive based MP3 players.
    Wayne
      • 46218
      For the Mp3 player you need to install Sveta Portable Audio, then right click from MMC >> Convert To >> mp3 player name.
