Batch Conversion?
  • leeje
    • Mar 2004
    • 9
    Batch Conversion?
    Does the music converter support batch conversion?
    Re: Batch Conversion?
    Install File Selector add on.
    • Razgo
      • 2532
      you will find file selector here: http://www.dbpoweramp.com/dmc.htm
      • leeje
        • Mar 2004
        • 9
        I was able to download and install the file selector, however I don't see a button, or any means to add files in multiple folders to a batch. Is that possible? How do I use the file selector for a batch conversion?
        Thanks, Jim
        • Razgo
          • 2532
          that's strange. have a look at the help file for it and see if everything is there. start-->programs-->dbpoweramp music converter-->help-->dmc file selector help
            You put a tick in the folder box.
