A few small changes
  • jtdavies
    • Feb 2004
    • 13
    A few small changes
    1. When using the option in Power Pack to automatically rip, if the CD isn't found in freedb go back to the main screen rather than rip to generic named files
    2. On the Music Converter progress dialog, keep the name of the album or artist up all the time. I'm ripping on two computers and can get confused.
    3. Maybe this is hard or maybe it's already done. I have lots of disk space. I'd like to be able to rip as fast as possible while I'm awake and in front of the computer but have the encoding be done in the background and queued up for when I leave the computer.
    • 46218
    Re: A few small changes
    Points taken, for point 3, if you rip to monkeys audio, that will be as fast as your computer can rip - later convert those monkeys (with file selector) in just a few clicks.
    • jtdavies
      • Feb 2004
      • 13
      The monkey audio solution worked great.
      I'm down to about 2 1/2 minutes per disc. Before I was ripping at 13 minutes per disc.
      For any lurkers, I had to set the Monkey Audio to fast and turn off all Power Pack DSP effects. I then do the DSP effects when converting to Microsoft media format.
