Shell integration?
    Shell integration?
    Hey,
    dbpowerAMP is a great program, and I use it exclusively for audio conversion. Part of what I like about it is that it does it's job without having too many unneccessary features that bulk up the program. However, I think it would be very useful to have dbpowerAMP integrated with the Windows shell, so that I could right click on an audio file and convert it. I don't know how hard this is to implement, but if it isn't hard, I think it's a worthwhile addition to the program.
    -Ben
  • MODatic
    • 230
    umm, it must have been disabled on your install because a convert to option is already present on the explorer context menu. To re-enable it, go to (on the start menu) dBpowerAMP Music Converter>>Configuration>>DMC Configuration and make sure that convert to on explorer right-click is checked then click ok.
    Cheers,
    [color=Blue][b]MODatic[/b][/color] :)
    [url=http://www.modatic.net/]modatic.net[/url]
