Tag problems
  • Arslonga
    • Jun 2021
    Tag problems
    My only complaint about your excellent ripping program is the difficulty of knowing in what order information on the tags to a ripped CD will appear on ones hard drive. I am never sure what item will show first, and I also don't understand why sometimes extra folders within folders will get created, so that navigating to find a particular piece can take a couple of more steps than strictly necessary, and knowing exactly what is in a particular file is difficult. I wonder if there's a post-facto fix for this, and I word urge you to provide clearer instructions for file labeling to new users of the program.
    Re: Tag problems
    File order is based on the filename, alphabetic, unless you write to a USB flash disk and as used in some cars (which is based on order written).
      Re: Tag problems
      Nothing is broken so there is nothing to fix. You probably need to read the help on Path and Naming.
      • Oggy
        • 704
        Re: Tag problems
        Yes, my Pioneer car unit does this reading from a USB stick: this is (obviously) the only time I see a random order.
        Can anyone suggest a way around this please?
          Re: Tag problems
          Naming and folder creation is not random, but based on how you have setup your path and dynamic naming string. See:
            Re: Tag problems
            TuneFUSION has a special write option which orders them correctly on a FAT32 formatted stick.
            • Oggy
              • 704
              Re: Tag problems
              Thanks Spoon.
              Does TuneFUSION integrate with Batch Converter? If not that write option would make an excellent DSP (please!!).
                Re: Tag problems
                It is not possible to do it as a DSP effect, TUNEFusion is stand alone, it has the abilities of batch converter, but better for the task.
                • Oggy
                  • 704
                  Re: Tag problems
                  TuneFUSION purchased and installed, will direct questions in that thread.
