Allowing for the disabling of DSP Effects
  • Dropbear
    • May 2020
    • 57
    I think it would be really useful, to be able to enable or disable DSP Effects at will. This would be tremendous for testing and debugging purposes.
    [SIZE=1]Assuming of course, that it would be relatively easy to implement. I don't know.[/SIZE]
    Every time I delete a DSP effect, I often then struggle to remember what parameters I had just successfully used.
    Sometimes I forget to write them down or take a screenshot.
    [SIZE=1]
    [SIZE=3]See example here: [/SIZE][/SIZE]Click image for larger version
Name:	Disabling DSP Effects.png
    What do you all think about this? Useful?
