MusePack Codec?
    MusePack Codec?
    Modatic's site
    http://www.modatic.net/
    is talking about transparent ripping at 160+kbps
    http://www.modatic.net/audio/best_lo...dio_format.php
    using a codec called Muse PaCK
    http://www.modatic.net/audio/mpc.php
    when will we be able to use dBpoweramp to play these files back?
  • totalXSive
    • 222
    Sometime soon. A codec is in development as we speak, though Spoon isn't having much luck with it :(.
    Currently, you can encode them if you have the Power Pack.
    [size=2][b]Neil T :)[/b]
    [url=http://www.neilturner.me.uk/]My weblog[/url] [url=http://www.audiopod.co.uk/]AudioPod - MP3 news[/url] :cool: [/size]
      • 46219
      The MusePack has me slightly confused - if I have it right, one guy was developing it, he stopped and it has been taken over by someone else who is also adding in things like monkeys audio?
      • MODatic
        • 230
        History lesson:
        MPC was developed by Andree Buschmann. Originally, he distributed the source code for the decoder. Frank Klemn, got his hands on the decoder source and made it a hell of a lot faster. Andree Buschmann trusted Frank and gave Frank Klemn the source code for the encoder. Frank Klemn made huge encoder speed increases of ~30%. Frank makes regular tunings and tweaks all the time to MPC (Andree is fine with them). His versions are more advanced, have more features (encoding from FLAC, LPAC and APE) and are far more tuned. Frank Klemn has been the lead coder so to speak, for the last 11 months. Andree hasn't released any official binaries from his website for the last 11-12 months.
        Please Spoon, when you make the MPC plugin, use Frank Klemn's version.
        Cheers,
        [color=Blue][b]MODatic[/b][/color] :)
        [url=http://www.modatic.net/]modatic.net[/url]
        • MPC Fanatic
          • Jun 2002
          I hope Spoon gets done soon because as my user name implies, I am an MPC Fanatic, the only format I use for lossy music compression is MPC (I also use Monkey's Audio for lossless archival purposes on a seperate computer) and I would like the convenience of converting it natively using dBpowerAMP Music Converter instead of using the CLI encoder and being able to play it in dBpowerAMP Audio Player.
