Dsp exitement
    Dsp exitement
    Hi guys, just downloaded the beta version, and thought that Dap would be the last surviving player on my system.
    The Dsp pluginin for winamp called Dee2 (enhance017 is similar), is so impressive that it is a "let-down" to play music without it. So after installing the beta version, I discovered that the Dsp support is not winamp compattible!!
    Have I missed something? - if so, how do I install third party Dsp's ?
    Incidently, if anyone wishes to try Dee2 (download from winamp's website),
    my tip would be to simply set the options no further than 30 percent, and only listen through quality "hi-fi" speakers.
    Best regards - JG
  • Razgo
    • 2532
    Re: Dsp exitement
    there is no 3rd party dsp pluggin for dap yet. but Spoon does plan for dx pluggins as far as i know.
      Re: Dsp exitement
      Thanks Razgo, maybe Spoon could implement his own version of DEE2 - after all, it is possibly the only plugin worth having (works like the "dbx" sub-harmonic synthesiser) ----- wishfull thinking ???
      Regards - JG
