CD Ripper: Warn if ripping to anything but 44.1kHz/16bit stereo
  • mikelee
    • Mar 2018
    Recently, I ripped a couple of hundred CDs without remembering that, months ago, I had been ripping multi-channel 48khz 24 bit DST CDs.
    Ah, but can't you just reprocess them with the Converter and downsample to 44.1/16/stereo? Yes, but the file sounds quite different than had you ripped it correctly in the first place. I tested with The Beatles Revolver, and there is a dramatic change in the stereo image and soundstage, and not for the better.
    Yes, I know I'm an idiot, but it's not really obvious which DSPs you have enabled, and it's easy to set and forget.
    Thank you!
    Re: CD Ripper: Warn if ripping to anything but 44.1kHz/16bit stereo
    Do you mean you ripped The Beatles Revolver DTS 5.1 disc?
