a repeat function for DAP
  • Narler
    • 74
    In a future version, can there be an option such as Repeat, to either Repeat current track, or Repeat complete playlist?
    At the moment, I notice that each track played is removed from the playlist?.. Why is this done?
    Say I use "Open Music File" and select the tracks I wish to play, once they have been played, I have to go and reselect all those files again?. Also this feature makes "Play Previous" button completely useless as it indeed does not re-play the previously played track.
    Yes I'm sure someone will say just use the playlist, and select En-Queue, to re-play the playlist, but adding files to the playlist or MMC just takes to long.
    Also on a similar note. say I have 19 tracks in a directory. called track-01.mp3 to track-19.mp3
    I choose "Open Music File", select each file either seperately or by selecting track-01.mp3 and then shift select track-19.mp3 (to select all tracks in order).
    Why is it that the en-queued list of tracks in MMC starts at track-19.mp3 ? instead of track-01.mp3 ?
    For instance the playlist goes:
    track-19.mp3
    track-02.mp3
    track-03.mp3
    track-17.mp3
    track-18.mp3
    track-01.mp3
    ? I can't understand why the tracks are not played in the selected order?
    cya
    • 46219
    That is just windows passing them in the wrong order - I could sort the final list
