metadata data entry screen
  • Timothy Wright
    • Mar 2016
    • 34
    I have two 4k displays, my main display is 40". When I rip I decrease resolution to 2560x1400 because otherwise everything is just too tiny to read.
    On occasions when no CD information is downloaded frequently I open a metadata window which can not be resized and it almost fills my entire screen making cut and past from any other window very tedious.
    I wish that window was HTML so I could zoom, or I wish I could at least resize the window to half screen.
    Thank you.
    Re: metadata data entry screen
    Try R16, it works well upto a scaling resolution of 300%, it is in the testing section of this forum.
