Fill a hole...
  • DrBob
    • Oct 2015
    Fill a hole...
    Often, when I rip a CD, one or two tracks fail to rip correctly. It would be great if I got the option to buy the track right then, so it would fill in the hole in my album. Ever thought about partnering with HDtracks or some such?
    Re: Fill a hole...
    You should buy a second drive. Often when I have ripping problems on a CD, ripping it on a different drive can solve the problem and I get a good rip. you can also use CueTools program to do "repairs" to bad frames in an error rip if there are not too many bad frames (and the CD in question is contained in the cuetools database).
