.MP3 to .RMJ converter
    If anyone has one can you email it to me at dj3212000@yahoo.com
  • Tatsuo Akira
    .mp3 to .rmj converter
    Really, I BUY, I know BUY a CD and save it to my drive and I cant even burn a custom mix...that SUX!
    Let me know if anyone has one...
    If so e-mail it to me at clanjet@hotmail.com
    if it's good, you may be rewarded
      Re: .MP3 to .RMJ converter
      RMJ to MP3 converter: Also if anyone has one can you send me it to xtreme28_uk@yahoo.com... Will be forever appreciated.
      • daren
        • 153
        Have you tried the dBPowerAMP Real Audio codec?
        There is a registry setting you can change if you want to make files with a
        .rmj filename extension instead of .ra.
        HKEY_CURRENT_USER\Software\Illustrate\dBpowerAMP\D MCRMExt
        Just set the value to ".rmj" and hey presto, the files come out with a .rmj
        filename extension.
        HTH,
        Daren.
          .... bob_23@gmx.de .....
            One of the above replies was quite correct you know. Rename the 'RMJ' file to 'RM' and then convert - theres your answer
