Year By Track
  • RoyalEF
    Year By Track
    Now I know the major databases don't have this data, but the CD ripper destroys this data when I enter it.
    I prefer that a Greatest Hits compilation to have accurate Release Years for each track in the primarily supported YEAR tag. A Jackson 5 Hit CD pressed in 2005 will set "I Want You" as 2005, instead of 1965 when it was actually released. If I make a smartlist of "Songs of the 1960s" these would never show up.
    What's worse is dBpoweramp deletes the year data I enter.
    I MUST complete my MetaData review first. Opening the Metadata review to make a change to a track will throw away all the individual years (so I suppose year should appear on the metaData review screen?)
    If I've completed all my other corrections, I then correct the year of every track. Immediately RIP the CD.
    Now unfortunately, once the CD is removed the Year data is lost. It isn't written to poweramp cache. If I need to re-rip, I'll have to enter all the years again. :-(
    Re: Year By Track
    I think this is because Illustrate likes to adhere as closely as it is possible, to tagging standards, which probably states that YEAR should contain the CD release year. Hence the behaviour you are seeing. (please don't quote me on this though, as I am not sure)
    Don't forget, you are able to add your own tags e.g. TrackReleaseYear and populate it with what you like.
    • RoyalEF
      Re: Year By Track
      I could add tags, but I try to keep the most relevant info in the most supported tags. Simply put, there was always a need of an AlbumYear vs a TrackYear. This would be helpful as my folder names include "([year])" which for a compilation now generate multiple folders (one per year). So "([album year])" would be lovely. I suppose I could create that tag for compilations. Make my life a little easier.
      There is a checkbox in CD Ripper that offers to force EACH TRACK GENRE THE SAME. I simply see a need to UNFORCE for EACH TRACK YEAR THE SAME. If it stored in the the db cache so I don't have to redo the work, that would be great.
      • BrodyBoy
        • Sep 2011
        • 780
        Re: Year By Track
        I agree with mville that dBp probably does this in adherence to common use of the YEAR tag to mean the CD release year. For certain kinds of CDs ...usually just big artist retrospective collections, in my case....I populate the ORIGYEAR tag for each track in mp3tag. I prefer the actual YEAR tag to be consistent for an album, as I have occasionally run into players where different YEAR values messed up the ALBUM grouping under certain circumstances. (Probably not a common problem, but a pain when it does.)
          Re: Year By Track
          I understand how annoying this. There are similar annoyances in CDRipper, e.g. where CDRipper insists on automatically ticking the Compilation box when the Track Artist varies on a CD, drives me mad. I have requested enhancements to CDRipper many times in the past but they never see the light of day, so I wouldn't hold your breath.
          A lot of my help/suggestions are often to get around metadata issues and I realise are not ideal for many end users.
          • Michael Sargent
            • Dec 2009
            • 135
            Re: Year By Track
            ... to tagging standards, which probably states that YEAR should contain the CD release year. Hence the behaviour you are seeing. (please don't quote me on this though, as I am not sure)
            I certainly hope not. For me, the most important date is the recording date, or lacking that the release date. That way I can listen to music in the correct chronological order. The date of the CD is probably the least important thing going.
            Mike
              Re: Year By Track
              I agree. YEAR for my library contains original recording/release date. However, I often have to change this because the YEAR populated by the online metadata database providers, is the CD release date. I manually add a Release Date tag for the CD release date.
              The problem for me is always the data provided by the online metadata database providers, it is just too inconsistent.
              • schmidj
                • Nov 2013
                • 599
                Re: Year By Track
                The same issue exists for Genre. If you enter different genres for tracks in the main ripper screen and then open the metadata review screen, it wipes out your genre entries and makes them all the same. I wish this action could be changed. it is mighty annoying, on otherwise excellent software.
                • PepsiCan
                  • Apr 2014
                  • 106
                  Re: Year By Track
                  I actually just logged the same request (sorry, missed this one until after I posted). There is a workaround as you can set the release date (and genre) per song in the main screen. But it is not logical. You want all metadata in one screen, not spread out over multiple screens.
                  • PepsiCan
                    • Apr 2014
                    • 106
                    Re: Year By Track
                    Right. But then the problem is solvable as there are separate meta fields for both types of information.
                    • BrodyBoy
                      • Sep 2011
                      • 780
                      Re: Year By Track
                      Not sure what problem you mean. I was referring to a player issue.
                      • schmidj
                        • Nov 2013
                        • 599
                        Re: Year By Track
                        The issue with the ripper is that if you open the "review metadata" screen after you have entered track-by-track years or genres, the dBPoweramp software replaces them all with (I think) the value for the first track, even if you don't change the settings for year or genre on the review metadata screen. I find this one of the few major annoyances in what is otherwise excellent, well thought out software.
                        • BrodyBoy
                          • Sep 2011
                          • 780
                          Re: Year By Track
                          Yeah, I get that....that was kind of the point of the thread. PepsiCan responded to my post, however, in which I was explaining why a completely separate issue (players that get tripped up by different YEAR tags on an album) has lead me to prefer the same YEAR on all tracks.
                          • schmidj
                            • Nov 2013
                            • 599
                            Re: Year By Track
                            Brody,
                            I'm not surprised there is an issue with players. But my point to Spoon is that it should be my choice on how to store my years and genres, not an arbitrary change made by dBPoweramp because I happen to open a particular window for a totally different reason. As I'm sure most of us are aware, although many of the databases may only have one value per album, on my server all metadata is stored per track, not per album.
                            Unfortunately the people writing much of the player software don't think this stuff out very well. The making of a particular album should be the album title, the album artist and the compilation flag, if it is one, not anything else. Now i realize this may turn out to be an issue with artists who have more than one "greatest hits" album. Perhaps the standards people should set one tag as "recording year" and another as "release year". I'm hoping the new version of Foobar, which Spoon is supposed to be involved in, is better in this regard, but I also need a better front end for it on my computer, dragging and dropping isn't very convenient.
                            • PepsiCan
                              • Apr 2014
                              • 106
                              Re: Year By Track
                              And doing so would also resolve the issue of re-releases of old albums. Did you know that Bohemian Rhapsody was apparently recorded in 1993? It wasn't. But that is when they did a remaster of the 1975 album. :-)
