Suggestion: "Intelligent" Conversion Feature
  • -ol-
    • Mar 2015
    • 12
    Hi everybody,
    I just did the following with my music library: I converted every file I had to FLAC-uncompressed, after half a day the whole affair is finished
    Some background on my idea: When I ripped all my CDs some years ago I already used FLAC but in a compressed setting (no uncompressed available at that time). I change to uncompressed at the moment it became possible. Result: A mix between compressed und uncompressed FLAC-files in my library. Right now the conversion process changes ALL audio files, including the ones that are already uncompressed.
    It would be great to include a feature that determines the state of the source file and leaves it untouched in case it already is in the destination state, i.e.
    source: flac compressed -> dest.: flac uncompressed,
    source: flac uncompressed -> skipped, taking care of the next file.
    It would speed up the whole process and avoid unnecessary alterations to the files. I assume the determination process might add a little time but after all the benefits are obvious, what do you think?
    Cheers,
    Oliver
    P.S.: I hope there isn´t such a feature already included and I´ve just overlooked it...
