MP3 Pro
    MP3 Pro
    First thing:I wanna say I've very much enjoy using poweramp. TY
    A lot of mp3-sites started using mp3 pro format. A lot on 64 Kbps and some on 80 Kbps. The quality is less then the old format from the songs i downloaded i think. I can understand why they're switching over. The size decreases by half comparing to 128 Kbps old format. I downloaded the Thomson plugin for winamp. Then i converted to wave. But the quality isn't that good not like converting from the old mp3 format.
    Will there be coming something for mp3 pro format to wave converting with the same quality as we're used to?
    Greetz Tony.
