A manual way to chose Flac encoder
  • thexfile
    • Jul 2010
    • 177
    Could a encoder location option be added to Flac please.
    I know Ogg (aoTuV) has that encoder choice option.
    Re: A manual way to chose Flac encoder
    That is because aoTuV uses a command line encoder, and effectively uses the dBpoweramp Command Line Encoder. Flac uses our own code linked to the flac library to encode, not the flac.exe encoder.
    You can install the dBpoweramp Command line encoder and point to FLAC.exe
    • thexfile
      • Jul 2010
      • 177
      OK. Thanks
