Encoders & path length
  • SAbboushi
    • Aug 2009
    • 25
    For mp3 encoder, it appears the filename is truncated in order to accommodate the path length limit and the last character of the truncated filename is then replaced with the last character of the filename as defined by the Naming scheme.
    For wma encoder, if the path length is too long, then the track is not ripped
    I would like dbPoweramp to highlight any file names with invalid path lengths so we know to fix them before the ripping/errors occur
    • 46217
    Re: Encoders & path length
    You can use [MAXLENGTH]250,EXISTINGNAMINGSTRING[]
    to always set to an acceptable length.
    • SAbboushi
      • Aug 2009
      • 25
      Thanks - this is still on my wishlist though ; )
