Please add info on "WindowsXPRemovePropHandler.exe" to a readme somewhere
  • JeffG
    • Jun 2012
    Is WindowsXPRemovePropHandler.exe a valid part of dbPowerAmp, and if so, could you please put a blurb of explanation about what it is and does in your FAQ and/or readme? Do XP service pack levels matter for this component?
    Google was useless as usual, and the phrase returns 0 hits in this forum. Thanks.
    Re: Please add info on "WindowsXPRemovePropHandler.exe" to a readme somewhere
    It is used internally, you never need to run this program, the install will run it if it is required on your system.
    • king943
      • Sep 2012
      I have two licence and would really appreciate if this can be explained. What's the purpose of this process? I've just got anti-malware warning on this under dBpoweramp! Users should be advised about this!
      I'm also worried because of this http://www.novirus365.com/Softwareantivirus/68973.html Thanks!
        We have been around 10 years, never once has dBpoweramp shipped with a virus, that website you link to, which has adverts all over it, well make your own mind up...
        The purpose of this program is to remove the Windows 7 property handlers for Windows XP (which does not use them).
        Here is the actual code for the whole application...
        int APIENTRY wWinMain(HINSTANCE /*hInstance*/, HINSTANCE /*hPrevInstance*/, LPTSTR /*lpCmdLine*/, int /*nCmdShow*/)
        if (XWinVer::IsWinVista() == false)
        XFileName Path(XApplication::ApplicationPath().w());
        XFileName Del;
        Del = Path.w();
        Del+=L"dBPropertyHandler.dll";
        Del.Delete();
        Del = Path.w();
        Del+=L"dBThumbnailProvider.dll";
        Del.Delete();
        return(1);
        That is all it does, removes 2 dlls
          Searching for that company, finds this...
          Read it, basically that 'anti virus' company flags the programs of a competitor (AVG one of the biggest) as a Virus!!
          What a scam, looking at what they report for our program:
          WINDOWSXPREMOVEPROPHANDLER.EXE reported infected operating system:
          Windows XP Professional
          Windows Server 2008
          Windows 98
          Windows 98
          Actually the program cannot physically run on Windows 98, it is compiled in Microsoft Visual C++ 2010, which requires XP as a minimum to run any program compiled...
