Silence & DVD Audio
  • Nightnurse
    • Dec 2011
    Silence & DVD Audio
    Thought I'd add 2 of my wishes in one post...:smile2:
    When converting a collection of audio files, a filter to remove the silence at the start & ending would be useful (or a filter to run on existing files)..:komisch9:
    Also, the ability to burn Audio DVD, I know that WAV files may be the only option...:komisch12
    • 46159
    Re: Silence & DVD Audio
    There is a DSP effect which can remove silence.
    • Nightnurse
      • Dec 2011
      I've found the Silence 'remover' - thanks for the speedy response. I've checked the DSP effects for another function, and I hesitate to ask in case it's there & I've missed it. Is there a DSP effect to join audio files into one?
        • 46159
        No there is not.
