rearrange and delete tracks in mmc
  • rrich
    strange but a simple feature does not seem to be implemented. do i really have to skip files i do not want to play
    from the list? is there no possibility to change the order of playing when playing once started? sometimes you get the wrong track or change your mind. what then? a possibility would be use "create playlist" which is a bit more flexible and nearly could be used as a workaround. but the problem still exists when you move up in the hierarchy and want to arrange the playlists! a bit more flexibility in playing please some hints on that!
  • Fred
    That's it man! I love dAP, but simple, useful, WinAmp-like playlist I miss more than a lot. Just look at FAQ - "How to repeat just one song?". Do you really thing that it is easy?
    And another tip: I cannot add whole directory/directories to the playlist - why? or How to do that?
    • donny
      • Oct 2002
      • 761
      A lot of people complained about this...
      So I made a program called the QueMaster - It does something like you asked for - download it from my signature and check it out....
      And for adding directories - there is a workaround for that - arrange the collection by filename(path) and then by using shift (or ctrl) select all the files you want and then add them to a playlist or enque them
