Enhancement to forum
  • xmon
    • Sep 2011
    Any chance you could add the forum to Tapatalk http://www.tapatalk.com/? It allows people to access it and post easily from mobile devices. Its supposed to be easy if your forum software supports it.
  • Razgo
    • 2532
    Re: Enhancement to forum
    I dont know much about tapatalk but i do know vbulletin as its own version https://www.vbulletin.com/index.php?do=mobile
    • xmon
      • Sep 2011
      Looks fine, but costs money and is perhaps more suited to advertising funded forums than support forums (you have to keep the revenue stream from the mobile access). It looks to be more complicated to set up too.
      My understanding is that you can enable tapatalk in a few minutes and its free because they charge users for the app (Most smartphones - 1.99 I think). The app then allows them to access any tapatalk enabled forum (not just one vbulletin enabled forum). http://www.tapatalk.com/plugin.php.
      That said, I have only used tapatalk app and never enabled a forum myself so I dont really know what I am talking about. I will soldier on with life without it.
