Filter for Missing Files
    When I move files around, I always have to go back to MMC and clean it up. It does show which ones are missing but there is no way to sort or filter by the ones that are missing.
    Click the icon column to sort on icons and the missing will be top or bottom.
    • MasterOfPuppets
      • Nov 2002
      • 139
      One feature that should be added would be 'Select Missing Files' instead of 'Highlight Missing Files'.
      I don't use the icon column and having removed it a while ago, the idea of being able to remove them without readding the column and then removing it would be nice.
      Toute votre base sont appartiennent à nous!!!
      • Joseph
        • Oct 2002
        • 211
        I just click the little square in the upper left corner and tell DBpowerAMP to sort my missing and new files and all my missing files are at the bottom and I just highlight and delete them all at once.
        - Joseph
