More output options
    More output options
    I had about 1100 WMAs and wanted to convert them to MP3s because they sounded better for me in Linux. So I put my computer to convert the files before i went to sleep. The estimated time was about 8-9 hours so i decided to check the comp in the morning.
    When I checked the progress in the morning, the computer was shutdown. I dont know wether it was a power cut or a problem with the computer but then i figured out that
    1. Only 907 of the files have been converted.
    2. The directory structure was not followed. (All the files were written to one directory.
    3. I think that the comp stopped because there might have been a filename conflict.
    So now I am figuring out how to find the files which were not converted. That will be a very tedious task!!!
    I hope a plugin or future versions of dBpowerAMP allow you to mirror the directory structure of the source files. This one feature would have solved all my problems.
    File selector will do that, run a small test on a few files first.
