Use audio fingerprint (PUID) when perfectmeta sources don't agree
  • EliC
    • 1175
    When perfect meta-sources vary significantly on the artist and/or album, which is often (nearly always) the case one discs with only 1 track, dBpoweramp should use accoustic fingerprinting to match the song(s) to MusicBrainz. Of course AMG has Lasso, but this is not likely to be free.
    • 46218
    Re: Use audio fingerprint (PUID) when perfectmeta sources don't agree
    We tested and the accuracy of such a system was not great.
    • EliC
      • 1175
      Interesting to hear that you looked at it. Did you try PUID or Lasso, or both? If it can only identify the artist, then compare that back against the various results from perfectmeta it could tell you which to choose.
      • EliC
        • 1175
        Spoon, just curious, when you tested this what it as a primary identifier or a backup identifier?
          • 46218
          Primary
          • EliC
            • 1175
            Thanks. I was really suggesting it as a backup method for when the primary method fails, as often happens on discs with 4 or fewer tracks (90+% of the time with single track discs). This could be triggered when there is extreme disagreement between the sources.
