Default To Multi-File WAV Conversion For Reference
  • Jamil
    • Oct 2005
    • 45
    This applies to dbpoweramp Reference:
    I would like to see the default changed from one file conversion to multi-file when performing a batch conversion to WAV. Additionally, change the DSP from multi-core to single-core allowing people to change the default behavior to the slow single file processing.
    Finally, allow the number of simultaneous file conversions to match the number of processor treads Windows shows that the CPU supports. So, a quad-core CPU that is hyper threaded should, by default, perform eight simultaneous conversions to WAV.
    You can see one performance test I did on this here: http://forum.dbpoweramp.com/showthread.php?t=22286
