Conversion to lame - Help info
  • Rudolf
    • Feb 2009
    • 8
    Hi dear Spoon,
    batch conversion, second window with
    Converting to (mp3 lame) - understood
    Target (VBR ABR CBR Free) - understood
    Encoding (fast normal slow) - should be marked not according to speed, but to quality, so (low normal high) and then the speed should be in the brackets. There is a tooltip, but on the help page I'd expect clear details as to quality and no such, pardon, wishy-washy words. The tooltip is better.
    Advanced / Channels: there are seven options, but only four are explained.
    So which is the setting for optimized treatment for each channel individually? Excluding joint leaves stereo, dual and forced stereo - meaning what?
    I do hope that dual is what I need...
    best wishes
    Rudolf
    Re: Conversion to lame - Help info
    Forced stereo
