The ability to fix tagging while ripping
  • andynormancx
    • Jun 2008
    • 13
    The ripper would be even better if you could fix your tags while ripping. So you would kick off the rip and the ripper would rip all the raw data.
    While it was ripping it would pop the tag fixing window and you would fix the tags. When you had finished the tags the ripper would then complete the encoding, using your fixed tags.
    For it work well the ripper needs to be able to complete your encoding in the background while you are ejecting the current CD and starting the ripping process for the next one.
    Or have I just described the batch ripper, I'll admit I've never looked to see how it works...
