Increment track number feature
  • TechVsLife
    • May 2007
    • 95
    It would be good if there were some way to automatically increase the track numbers by a certain number. I often have multi-disc cds that I want to store as one "album" in one folder etc. That means turning track numbers on the current disc into trackNo + "n", where n is the total number of tracks from the previous discs in the series.
    if track 15 is the last track on disc 1, then
    disc 2 track 1 => track 16
    disc 2 track 2 => track 17,
    etc.
    Also would be good to allow the reverse operation, subtract a certain number from all tracks.
    Another similar request would be to be able to resequence the track numbers so that missing track numbers are eliminated.
    e.g.
    track 1 => track 1
    track 3 => track 2
    track 4 => track 3
    Or to allow multiplication by a certain number such as 10, in order, for example, to insert other tracks between them (and then to resequence).
    track 1 => track 10
    track 2 => track 20
    etc.
  • TechVsLife
    • May 2007
    • 95
    Re: Increment track number feature
    ok, I see now that there is a track offset feature on the dbpoweramp cd ripper, so ignore the first set of requests.
