atrac3 codec
    atrac3 codec
    I posted this msg in the wrong forum b 4
    so here it is again
    my prob is i just bought a new sony md player and when you incode it with open gm(the incoding software that comes with them md player) you can only play the files in open gm. So i downloaded the atrac3 codec off the net and have been using dbpoweramp to rip off the cd and gold wave to incode to atrec3 and when i do it this way it works in open gm and winamp .etc. so i was wondering if n e one could make a codec plug in so i can go straight from cda to atrec3 using dbpoweramp???
    come on mr. spoon throw us a bone..yay/nay.. i will try... etc
      • 46218
      The only atrac3 codec released is a ACM Wave codec by Sony, it should work already with dMC.
        well then how do i get poweramp to recognise that i have the codec installed?
          umm i c now.. i can b so stupid... ignore that lost post... infact ignore this intire thread.
            Ok...
            I'm stupid, how do I get the program to see that I have the codec? (Not the same guy that posted before by the way!)
              • 46218
              Convert to >> Wave >> click 'Change'?
                Ah, my bad, I didn't have it to start with... where might I get this codec? (Sorry!)
                  • 46218
                    Is there any way to covert Sony .omg to MP3 using your software? Or do I have to re-burn every song that I've burnt using Open MG from CD again with dbPowerAMP?
                      • 46218
                      Reburn, I know of nothing that will touch .omg
                        cheers anyway, stupid sony format...
                          what to do with the zip file???
                          Sorry, the question may sound a bit silly but when i have downloades the zip file you have mentioned before, what do i do with it then???
                            hello mr spoon could you answer my question???
                              Re: atrac3 codec
                              Easy, you unzip the files, then right click on the .inf file and choose install
