Multi-Select and Enter Compilation Artist Names
  • kweller
    • 175
    I'd like to be able to multi-select a number of tracks for a compilation album and enter the artist name. At the moment the program just enters the artist name against the first track selected.
    Kevin
    Re: Multi-Select and Enter Compilation Artist Names
    agree !!! this should be a powerful option !!! i think the dBpowerAMP lose from this ... but if they fix it ...hehe ... it will really rocks ... the cds i own are 90% compilations and only 10% artists albums .. i use the easy cd extractor for extracting and the dBpowerAMP for converting ... if dBpowerAMP had this option i would uninstal the easy cd extractor .
      If you are talking about ripping a compilation cd and if you have the Power Pack installed, when you get your information from the freedb database, click on the button that reads Compilation (on the same bar as the preview feature and just to the left of Rip as One on the right side of that menu bar).
      Bill Mikkelsen
