re rip
  • gldr
    • 8
    re rip
    it would be great if dbpoweramp could skip a file (error) if the rerip is more than x frames.
    • 46218
    Re: re rip
    This option is in R13.
    • mbuczek
      • Nov 2008
      Re: re rip
      It would be great to have the opportunity to use dbpoweramb to re-rip discs that have failed in RipNAS. It is manually possible, but would be better if the dbpoweramp installation on windows home server could use rip data from RipNAS.
        • 46218
        Re: re rip
        You would get the same results, no? RipNAS uses dbpoweramp.
