Audio Input Request
  • Kapkirk
    • Dec 2007
    • 8
    Audio Input Request
    Please create another version of Audio Input that will allow us to continue to rip our old vinyl and cassettes.
    I've been using Poweramp for years. A lot of us long time users still need that functionality going forward.
    It's a pain to install two versions of the same software, and have it installed with two sets of codecs.
    If something screws up it makes it more difficult to troubleshoot.
    Regards.
  • scdb
    • Nov 2008
    Re: Audio Input Request
    KapKirk:
    I heartily agree!!
    • Kapkirk
      • Dec 2007
      • 8
      Currently I am not able to use the Auxillary product anymore. I am now getting the Windoze error:
      'Auxillary.exe has had a problem and needs to close...do you want to send information to MS?'
      This is probably the 5th time I've had to dual re-install the software over the last year, this is really becoming tiresome.
      :vmad:
        What version of dMC do you have installed? Aux Input doesn't work if dMC r12 or above is installed as the same directory as it: http://www.dbpoweramp.com/legacy-compatibility.htm
        • Kapkirk
          • Dec 2007
          • 8
          I've got the installation in two different directories.
          DBpoweramp12_4 and a separate one for 11.5 in the directory just called dbpoweramp.
          Path is c:\programfiles\illustrate\ then the directories. I am in the middle of a clean uninstall right now. I will post results when I complete the reinstall.
          Lt.Data, thanks much for the follow up on this.
          • Kapkirk
            • Dec 2007
            • 8
            All is well. Clean reinstall seems to be working again.
            Still though, would be nice to have all in one package.
