Clear sign DSP effects are being applied in CD ripper
  • matt_t
    • Feb 2008
    • 80
    Would be nice if during the encoding process in CD ripper there was a very visible warning to say "you do know you're applying DSP effects to this rip, don't you?" If you have the encoder window at the front, it would be easy to forget.
    In fact, for this reason I only install DSPs when I (very rarely) need them, and uninstall afterwards, just to make sure I don't make a botch of ripping a lot of CDs and then have to do 'em all again.
  • Thg6276
    • Aug 2008
    • 187
    Re: Clear sign DSP effects are being applied in CD ripper
    Hi, Just for my information, when we use a dsp, in the log file it is mentionned something like :
    Encoder: FLAC -compression-level-8
    DSP Effects / Actions: -dspeffect1="HDCD="
    I suppose that when we use an other dsp as this one it is the same thing?
    I am correct?
    • Porcus
      • Feb 2007
      • 792
      Proposed solutions:
      - Remember whether the Encoder tab was on top last time program was open or the DSP tab was, so that those who rarely change encoder settings can have the DSP tab visible all the time
      - Color the DSP tab if there is a DSP activated
      In fact, I am using FLAC -8 with verification, and applying HDCD -- these pieces of information could easily fit into the same mini-window. What about a combined Encoder and DSP tab, with a movable ruler separating them?
