Trim filename and path to x number chars
  • moley6knipe
    • May 2008
    • 97
    Been having some problems with dBpoweramp reference 13 ripping long filenames and paths in Apple Lossless.
    Win XP Pro SP2
    dBpoweramp reference 13 registered
    Multi-encoding to...
    Apple Lossless R8 codec
    Lame 3.97 codec
    For example, if my intended ripping path/filename is...
    C:\Documents and Settings\Colin Wheatley\My Documents\My Music\iTunes\SqueezeCenter and AppleTV Library\iTunes Music\+DBPOWERAMP RIPS+\Rod Stewart\Reason To Believe; The Complete Mercury Studio Recordings [Disc 01]17-You're My Girl (I Don't Want To Discuss It).m4a
    ...then the resulting file is in a directory called...
    ...Reason To Believe; The Complete Mercury Studio Recordings [Disc 0\17-You're My Girl (I Don't Want To Discuss It).m4a
    ...and the file is invalid. Oddly the mirror directory structure of mp3s is fine...
    C:\Documents and Settings\Colin Wheatley\My Documents\My Music\iTunes\iPod Library\iTunes Music\Rod Stewart\Reason to Believe; The Complete Mercury Studio Recordings [Disc 01]\17-You're My Girl (I Don't Want to Discuss It).mp3
    ...is a valid file. But I guess that's a marginally shorter path.
    so, please can I request an option to trim filenames/paths to x number of characters, preferably with the option of where to lose the characters, ie from alubm name or filename.
    Thanks!!
  • moley6knipe
    • May 2008
    • 97
    Re: Trim filename and path to x number chars
    I should add that I've reorganised my ridiculous file path so I've shaved a 101 characters off the full filename and path!
    So I've got a workaround, but the above took me ages to suss out what was going wrong!
      • 46218
      I will look at it for r13.1
      • EliC
        • 1175
        The best way to do this would be:
        [MAXCHAR]count,string[] <<-- Not a real command, dont use
        You could then specify in a nested manner how many to allow for each part
        [MAXCHAR]20,[ALBUM][]
        so
        becomes
        • EliC
          • 1175
          Couldn you use the SETLEN command?
          [SETLEN]count,pre,post,string[]
          [SETLEN]20,,,[ALBUM][]
          • Teknojnky
            • Dec 2006
            • 323
            the windows documents & settings folder causes alot of problems with long path/filenames.
            Best to have a short \music or similar root folder to shave a ton of useless characters from the path.
            Want to see [url=http://www.last.fm]Last.FM[/url] relationships using your own library?
            Want a random mode based on track and artist relationships?
            [url=http://www.mediamonkey.com/forum/viewtopic.php?t=24879]Try Last.FM Node[/url] for [url=http://www.mediamonkey.com]MediaMonkey 3![/url] ([url=http://img178.imageshack.us/my.php?image=lastfmnodemediamonkey3fj3.jpg]screenshot[/url])
            [url=http://www.last.fm/user/teknojnky/?chartstyle=Geldropdown-small][img]http://imagegen.last.fm/Geldropdown-small/recenttracks/teknojnky.gif[/img][/url]
            • EliC
              • 1175
              yeah, you will get the best bang for your buck by changing
              to
              Music\
              • moley6knipe
                • May 2008
                • 97
                Yeah, thanks folks, done exactly that! I've always put music in a folder on the root before, but started ripping before I'd thought about it when I bought my latest PC!
                I have indeed since discovered setlen, which works nicely (I truncate filename to 30 characters). A global setting might be nice though - perhaps something that could restrict all folders/filenames past a certain point in the folder path to x characters each, or x characters shared between the remaining filepath?
                As an aside, I rip to Apple Lossless using ref 13. When I used to rip to Apple Lossless using iTunes, it would create the filenames with 36 characters being the maximum it would use.
                And as a Squeezebox user, I know there's a problem with SqueezeCenter not being able to play AAC or ALAC files whose filename is above 63 characters; I think it's a limitation of QuickTime on a Windows machine, which is what SqueezeCenter calls on to transcode these formats.
                Just a couple fo points in case they're of use! Cheers for the pointers folks!
                  • 46218
                  It was multi encoder which needed recompiling with our latest code, now fixed:
                  http://forum.dbpoweramp.com/showthre...1530#post81530
                  • moley6knipe
                    • May 2008
                    • 97
                    Great, thanks! Nice work fixing the "can't type more than visible" in filepath bug, been meaning to post about that!
                    • dvdr
                      • Sep 2008
                      • 235
                      Hi
                      I just don't get this to work. I am using the default value plus the SETLEN command as described here - but whatever I do, the filename ALWAYS is extended to 180 characters! I would love to limit it, in case it should be longer, but if it's shorter, than not extend it...
                      Here's what I have been using:
                      [IFCOMP][IFVALUE]album artist,[album artist],Various Artists[]\[album][IFMULTI] Disc [disc][]\[SETLEN]180,,,[track] - [artist] - [title][][][IF!COMP][IFVALUE]album artist,[album artist],[artist][]\[album]\[SETLEN]180,,,[artist] - [album][IFMULTI] Disc [disc][] - [track] - [title][][]
                      Am I missing anything? Any error in the code? All plugins are updated to the latest version, also the multiencoder, in case it would interfere (you rewrote some code, as I read)
                      Thanks for helping.
                      [SIZE="1"][B][I]WHS ACER H340 w/ Asset V3, Linn Sneaky, Plugplayer/Songbook/Kinsky, Music mostly *.flac[/I][/B][/SIZE]
                        • 46218
                        Try R13.1 and use the new (not in multi encoder):
                        [maxlength]180,xxxxxxxxxx[]
                        • jason_s
                          • Oct 2007
                          Does the new [maxlength] option work with Arrange Audio through Batch Converter in 13.1?
                          Not having any luck so far...
                            • 46218
                            No it would not.
                            • dvdr
                              • Sep 2008
                              • 235
                              Hi
                              After experimenting with the trial, I bought dBpoweramp (the trial absolutely convinced me!) and am currently running 13.1
                              Where would I set the proper command to limit my character-count to let's say 180 in the following naming-scheme:
                              [IFEQUALS]genre,Classical,[IFCOMP]Compilations\[album][IFVALUE]album artist,\[album artist]\,[]\[IFMULTI]Disc [disc] - [][track] - [title] ([composer] - [artist])[][IF!COMP][composer]\[album] ([year])\[IFVALUE]album artist,[album artist],[artist][]\[IFMULTI] Disc [disc] - [][track] - [title] ([album] ([composer]) - [artist])[][][IF!EQUALS]genre,Classical,[IFCOMP]Compilations\[album][IFVALUE]album artist,\[album artist]\,[]\[IFMULTI] Disc [disc] - [][track] - [artist] - [title][][IF!COMP][IFVALUE]album artist,[album artist],[artist][]\[album]\[IFMULTI] Disc [disc] - [][track] - [title]([artist] - [album])[][]
                              Thanks for helping!
