I would like to have an option to dMC which merely copies the file as-is, with the option to choose DSPs which at most affect metadata. (Among them delete source, but in case source and target are on the same drive, "Move" should be rename.) A "preserve time stamp" option would be appreciated.
Reasons:
-> If at first you use dMC, then this -- with Batch Converter -- would probably be the easiest "rename folder by tags" utility. (Any other suggestions, anyone?)
-> For backup and for moving to a different hard drive, then the verify audio option is just what you need in order to ensure a good copy
-> To add ReplayGain & move.
Reasons:
