Dynamic Output Location
  • Des
    • Jul 2007
    • 36
    It would be nice if there were a quick way to select the 'Dynamic' part of the output location when running the convertor. Depending on what I'm doing, I often have to switch this; I have text file with lines that I cut and paste in the 'Set' field. Simply having a 'history' on the field, like the 'folder' field above, would be sufficient.
  • EliC
    • 1175
    Re: Dynamic Output Location
    What are you switching based on?
    I would like to be able to set an output directory for completely secure rips (all tracks ripped secure/accurate) and a separate directory for insecure/inaccurate rips.
