Advanced Options in codecs
  • kotrklai86
    • Dec 2002
    dMC Mp3 (LAME) does not have "Forced J-Stereo" switch, "auto
    channel selection mode" and "auto resampling mode". What VBR encoding is being used by Mp3 (LAME), New , Old.....?? I think dMC should add numbers for the VBR Quality slider!
    LOWPASS and HIGHPASS! I hope dMC will add a low/highpass
    switch for both MP3(LAME) and OGG........it will be easy if I could enable/disable/specify low/highpass directly from dMC 'cause I hate using Command Line Interface!
