Hide Codec Packs and DSPs as updates in XP...
  • toNka64
    • Mar 2007
    • 25
    It always drove me nuts how every single codec pack was listed in my Add/Remove Programs in the Control Panel (I know I'm anal).
    I wish they would be hidden like updates are.
    Then I figured out how to do this using the registry.
    Have a look at what I'm talking about.
    After applying my registry tweak it looks like this:
    Ah, nice and clean.
    No extra clutter.
    If I click on the "Show Updates" then it looks like this:
    !!!CAUTION!!!
    Editting your registry can damage your OS.
    Don't touch this idea unless you know what you are doing.
    Note: the DIR are machine specific, if you use the default install DIR it should be the same.
    Here's the reg code if anyone wants to use it:
    Code:
    Windows Registry Editor Version 5.00
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\dBpoweramp FLAC Codec]
    "DisplayName"="dBpoweramp FLAC Codec"
    "UninstallString"="\"C:\\WINDOWS\\system32\\SpoonUninstall.exe\" <uninstall>C:\\WINDOWS\\system32\\SpoonUninstall-dBpoweramp FLAC Codec.dat"
    "InstallTo"="C:\\Program Files\\Illustrate\\dBpoweramp"
    "ParentKeyName"="dBpoweramp Music Converter"
    "ParentDisplayName"="dBpoweramp Add-ons"
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\dBpoweramp Monkeys Audio Codec]
    "DisplayName"="dBpoweramp Monkeys Audio Codec"
    "UninstallString"="\"C:\\WINDOWS\\system32\\SpoonUninstall.exe\" <uninstall>C:\\WINDOWS\\system32\\SpoonUninstall-dBpoweramp Monkeys Audio Codec.dat"
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\dBpoweramp Mp2 and BwfMp2 codec]
    "DisplayName"="dBpoweramp Mp2 and BwfMp2 codec"
    "UninstallString"="\"C:\\WINDOWS\\system32\\SpoonUninstall.exe\" <uninstall>C:\\WINDOWS\\system32\\SpoonUninstall-dBpoweramp Mp2 and BwfMp2 codec.dat"
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\dBpoweramp mp3 (Fraunhofer IIS) Codec]
    "DisplayName"="dBpoweramp mp3 (Fraunhofer IIS) Codec"
    "UninstallString"="\"C:\\WINDOWS\\system32\\SpoonUninstall.exe\" <uninstall>C:\\WINDOWS\\system32\\SpoonUninstall-dBpoweramp mp3 (Fraunhofer IIS) Codec.dat"
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\dBpoweramp Music Converter]
    "DisplayName"="dBpoweramp Music Converter"
    "UninstallString"="\"C:\\WINDOWS\\system32\\SpoonUninstall.exe\" <uninstall>C:\\WINDOWS\\system32\\SpoonUninstall-dBpoweramp Music Converter.dat"
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\dBpoweramp Ogg Vorbis Codec]
    "DisplayName"="dBpoweramp Ogg Vorbis Codec"
    "UninstallString"="\"C:\\WINDOWS\\system32\\SpoonUninstall.exe\" <uninstall>C:\\WINDOWS\\system32\\SpoonUninstall-dBpoweramp Ogg Vorbis Codec.dat"
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\dBpoweramp Ogg Vorbis Lancer Encoder]
    "DisplayName"="dBpoweramp Ogg Vorbis Lancer Encoder"
    "UninstallString"="\"C:\\WINDOWS\\system32\\SpoonUninstall.exe\" <uninstall>C:\\WINDOWS\\system32\\SpoonUninstall-dBpoweramp Ogg Vorbis Lancer Encoder.dat"
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\dBpoweramp WavPack Codec]
    "DisplayName"="dBpoweramp WavPack Codec"
    "UninstallString"="\"C:\\WINDOWS\\system32\\SpoonUninstall.exe\" <uninstall>C:\\WINDOWS\\system32\\SpoonUninstall-dBpoweramp WavPack Codec.dat"
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\dBpoweramp Windows Media Audio 10 Codec]
    "DisplayName"="dBpoweramp Windows Media Audio 10 Codec"
    "UninstallString"="\"C:\\WINDOWS\\system32\\SpoonUninstall.exe\" <uninstall>C:\\WINDOWS\\system32\\SpoonUninstall-dBpoweramp Windows Media Audio 10 Codec.dat"
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\dBpoweramp [Calculate Audio CRC] Codec]
    "DisplayName"="dBpoweramp [Calculate Audio CRC] Codec"
    "UninstallString"="\"C:\\WINDOWS\\system32\\SpoonUninstall.exe\" <uninstall>C:\\WINDOWS\\system32\\SpoonUninstall-dBpoweramp [Calculate Audio CRC] Codec.dat"
    Spoon, if you can added this in a future release it'd be cool.
    The question is... who really cares about stuff like this but geeks like me...?
    • 46219
    Re: Hide Codec Packs and DSPs as updates in XP...
    I am not sure hiding the codecs as an update would help people, just means they cannot uninstall a codec easily.
      It sounds like a good idea to me, but what Spoon said is probably correct: most users would never know to check that box to see the codecs.
