Large track offset and 3 digit track numbering
  • tkolla
    • Jun 2007
    I just upgraded from version 11 to 12 and miss some little things.
    I rip not only music but also audio books.
    Some of them are very large (e.g. Harry Potter books with up to 30 CDs) and the number of tracks is also very large. Renaming files and editing ID-tags after ripping is awful.
    So please reintegrate the possibility to define larger offsets as was possible in version 11 (a custom offset ranging up to 999 would be great).
    According to this it would also be useful if automatic file naming would include the possibility to pad the track number to 3 digits (this was also a feature of version 11).
    Last wish is to integrate the profile feature into the Power Pack version as this is the only feature of the Reference version that is useful for a normal user like me (I always rip music with a higher bitrate than books).
    Best wishes
    Thomas
    Re: Large track offset and 3 digit track numbering
    In R12 you can set the offset +99, then set it again +99, etc...
    You can pad to 3 chars using Reference programmable elements, in the naming string replace [track] with:
    [SETLEN]3,48,,[track][]
    • tkolla
      • Jun 2007
      Thank you very much for the fast reply.
      Thomas
