It would be nice since I cannot convert real files to wave if you could create an auxillary like the one that was installed with 11.5. That was a great item, unforunately as LtData knows, I cannot convert with version 12.1, nor could I convert using 11.5. With 11.5 when I copied the and display all of the files from my older pc which had winxp and loaded to my new cp(vistahomebasic) it would not produce sound.
Don't know what the problem was.
Thanks for any consideration.
