CLI for musicmatch....
    Musicmatch's mp3pro converter is AWESOME but lacks the "customizability" that yours has... ie: overwrite/delete old files, queuing up an entire playlist, etc....
    oh yeah, because registered users of MM can encode at higher mp3pro bitrates!!!
      You will not like me saying this, any mp3PRO file encoded at 128 or higher will sound worse than a normal .mp3 file (encoded with Lame).
        i know but any mp3pro file 80kbps converted from cd will sound better on a good system than one at 64....
        • Joseph
          • Oct 2002
          • 211
          AAC Pro
          The format AACPro claims to have cd quality sound at 48 kbps according to various listening tests. Will it be possible for DB Poweramp to support the AACPro Format?
          - Joseph
            We will have to see, often these smaller (as in not widely used) codecs are difficult to add.
