Multidrive Extraction Queue
  • Tigerix
    • May 2007
    Hi everybody,
    There is one thing which would really ease / speed up my ripping processes.
    I have 3 CD/DVD drives and I would like to use them all.
    Currently I have to start the rip process for every drive manually after the previous has finished. It would be great if I could add songs from different drives to a job queue. So I just have to prepare everything, click on rip and can go away from the computer (and don't have to disc jokey) and let DMC rip drive by drive all my inserted CDs.
    Anyone the same wish?
  • EliC
    • 1175
    Re: Multidrive Extraction Queue
    you can also start the ripper 3 times, one for each drive. Hopefully, in future releases spoon has drive tabs, so the ripper only needs one window but can rip from multiple drives at the same time using a different tab for each drive.
    • Teknojnky
      • Dec 2006
      • 323
      I use 2 or 3 drives to rip at the same time also, but as mentioned you need to start a new copy of the ripper for each drive. It seems to work fine, however it would really be alot more convenient to manage ALL drives via ONE ripper instance (via tabs or whatever other UI manangement).
      • dbPowerBOY
        • Sep 2006
        • 61
        The 'drive tabs' idea would be excellent, I can picture it visually
