Reference codecs
    Reference codecs
    I would like to see an option when installing Reference to install all, none, or specific codecs during the installation.
  • EliC
    • 1175
    Re: Reference codecs
    Agreed. I dont need or want most of the codecs that come with reference.
      Its not that I mind the codecs installed, but today I had to do a re-install, which overwrote some codecs with older versions.
      • Teknojnky
        • Dec 2006
        • 323
        /3rd'd for all the reasons mentioned
        Want to see [url=http://www.last.fm]Last.FM[/url] relationships using your own library?
        Want a random mode based on track and artist relationships?
        [url=http://www.mediamonkey.com/forum/viewtopic.php?t=24879]Try Last.FM Node[/url] for [url=http://www.mediamonkey.com]MediaMonkey 3![/url] ([url=http://img178.imageshack.us/my.php?image=lastfmnodemediamonkey3fj3.jpg]screenshot[/url])
        [url=http://www.last.fm/user/teknojnky/?chartstyle=Geldropdown-small][img]http://imagegen.last.fm/Geldropdown-small/recenttracks/teknojnky.gif[/img][/url]
          • 46217
          Only the version.txt would be overwritten, not the codec its self as the version number of the codec.dll is is later.
            OK, so the version aren't over-written, but if I could skip the codec installation when I don't need it, Reference would install faster.
              • 46217
              Perhaps we should do a reference without codecs, something to think on.
                That sounds like a good idea, but do you mean two versions: a version with and a version without codecs?
                • Teknojnky
                  • Dec 2006
                  • 323
                  2 versions seems more work than making the installer more flexible to make codecs optional than 2 different (and thus even more confusing than it already is) installs.
