Advance 5 SECS
  • SOT
    • Jun 2002
    • 36
    Advance 5 SECS
    Hi there!!!
    Thanks a lot Spoon, I was waiting for advance 5% on the control freak and it works great. But is there any way to advance 5 SECONDS? 5% is sometimes too much. My hard trance musics have often more than 7mins, and 5% advances 25 seconds...
    THX A LOT
    Keep up the Xcelent work!
    SOT
    • 46218
    I was a bad coder when it came to externally setting the position...it can only set on a 1 percentage basis, so if you had a 10 minute track it would have a 6 second granularity. If I did something that was 5 seconds and someone tried it on a massive track it would just not work. Perhaps that section needs rewriting.
    • SOT
      • Jun 2002
      • 36
      Hi again,
      No maybe not. Just add an option to advance/rewind X percent, where the X is a user made setting. :p
      Or, you can add Advance 10,5,4,3,2,1 percent options. Like, pressing F1 advances 1%, F2 2%, and so on.
      Of course... those keys should also be added to the control freak package:smile:
      It is trully right that a rewrite would make things better, but, you maybe have priorities, and this would be a fast solution.
      CYa
