Track offset
  • dizwell
    • Feb 2007
    • 27
    Track offset
    The track offset feature in version 12 of dMC is one of the main reasons I bought the product: it makes doing a boxed set **soooo** much easier!
    However, it's not as easy as it could be: some of my offsets are in the 80+ range, and that means four trips to the 'Apply Track Offset Number' menu. It would be a lot easier if I could just type the offset in -or, at least, use a spin control to increment/decrement the number, instead of having to repeatedly select from what is, after all, a pretty clumsy menu.
    Just a thought for the future...
    [URL=http://www.dizwell.com/prod]Dizwell: All things Oracle, Linux and... er, Misc[/URL]
